1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to use BOY/OPI to produce standalone simple displays
To: Jimmy Johnson <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 01 Dec 2010 14:42:53 -0500
Hi:
On 12/1/10 14:11 , "Jimmy Johnson" <[email protected]> wrote:
> Basically our operators are used to being able to X display many
> discrete UIs onto their desktop ...
> That said there are definitely benefits to the CSS integrated tools
> support ...
Right, there are benefits to both.
> ... I was hoping ... something along the lines of
>     "boy_displaymanager   test.opi"
Yes, we'd like to have something like that, too.
Here at the SNS we have mostly EDM screens, and there's no need to replace
them in the foreseeable future.
Still, it would be great to be able to open new CSS OPIs from the existing
EDM screens, via a command-line tool as you describe.
Java code tends to have a certain startup time.
Starting CSS can be slow, while opening another display within the running
instance is then no problem.
Plus I would still include at least probe, PV tree, Data Browser
PV-fields-viewer with SNS Database connection, SNS logbook support, settings
for SNS network in that tool.
So I don't think a boy-only product is the solution.
Better would be something that signals the already running instance of CSS
to open another screen.
-Kay
RE: How to use BOY/OPI to produce standalone simple displays Jimmy Johnson
Prev: RE: How to use BOY/OPI to produce standalone simple displays Jimmy Johnson
Next: Re: CSS/Trend and small numbers Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Build EPICS Base3.14.9 on Windows 张玉亮
ANJ, 01 Dec 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
