1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: string array PV
To: [email protected]
Date: Thu, 2 Dec 2010 13:22:43 -0600
On Thursday 02 December 2010 12:44:27 Pierrick Hanlet wrote:
> Is there any record type that can contain an array of strings?
Assuming by string you mean a normal 40 character DBF_STRING the waveform
record can hold an array of any type and size.  If you want more than one of
them an aSub can hold up to 42 arrays of any type and size (21 input fields A
.. U and 21 output fields VALA .. VALU).
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
string array PV Pierrick Hanlet
Prev: Re: string array PV Tim Mooney
Next: Re: string array PV Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RTEMS BSP for the KineticSystems VXI V152 PPC slot-0 Controller? Allison, Stephanie
ANJ, 02 Dec 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
