Great. Thanks for testing thig.
1) Should we make this an option to the vxi11Configure command?
Pro: Allows locking to be controlled
Con: But only on a fairly coarse granulatiry and that command already has a lot of arguments to keep track of.
2) I can't explain why terminating the program with a ^C would leave the socket in any different state than terminating the program with an explicit exit. As far as I know the VXI-11 driver installs no 'atexit' handler to do anything special so the socket should end up getting closed by the kernel in either case.
On Dec 2, 2010, at 12:35 PM, William Lu wrote:
> I set the crLinkP.lockDevice to 1 as Eric suggested, and it does the trick! My ioc locked the devices exclusively.
> Additional findings:
> 1, the ICS 8065 Ethernet-GPIB controller has a configurable timeout for the communications with the TCP/IP clients. If the ioc does not communicate with any GPIB devices for the timeout amount of time, the 8065 will release all locks created by the ioc.
> 2, if the ioc is terminated by the iocshell "exit" command, the 8065 does not release the locks created by the ioc until the communication timeout expires.
> 3, if the ioc is terminated by ctrl-c in the iocshell, the 8065 releases the locks created by the ioc immediately. It seems that the ioc upon "exit" does not unlock the links nor close the sockets, whereas ctrl-c at least does one of them.
> Thank you Eric and Mark for your help.
> Best regards,
> William
Eric Norum
[email protected]
- Re: Asyn VXI-11 Driver and VXI-11 Locking William Lu
- rtems-4.10 tftp support Jim Chen
- Asyn VXI-11 Driver and VXI-11 Locking William Lu
- Re: Asyn VXI-11 Driver and VXI-11 Locking Eric Norum
RE: Asyn VXI-11 Driver and VXI-11 Locking Mark Rivers
<2010>
2025
2026
<2010>
2025
2026
