1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: New StreamDevice version
To: [email protected]
Cc: [email protected]
Date: Fri, 03 Dec 2010 11:59:50 +0100
Hello Craig,
Thanks for testing it on Mac.
The effect you found is indeed an incompatibility. I think I better remove it again and look for something better. I was trying to be more compatible with the sscanf format strings, where a space consumes arbitrary amounts of whitespace (see: man sscanf). Thus in your case it is not the last %s but the spaces after the %s that consume the \r\n. I think I better remove that feature again to stay backward compatible. Maybe I better go for a special escape sequence for "arbitrary amount of white space".
Dirk
[email protected] wrote:
Hi Dirk,
Thanks for the new release. I can confirm it builds OK on Snow Leopard 10.6.5. I've run into a difference with the previous snapshot though. I have a protocol as follows
InTerminator = "> ";
OutTerminator = CR LF;
ExtraInput = Ignore;
get_airTemp {
    out "R1";
    in "R1\r\n%*s   ,%*s   ,%*s   ,%*s   ,%*s   ,%*s   ,%*s   ,%*s   ,%*s   ,%*s   ,%*s   ,%*s   ,%*s   ,%*s   ,%*s   \r\n%*f,%*f,%*f,%f,%*f,%*f,%*f,%*f,%*f,%*f,%*f,%*f,%*f,%*f,%*f";
to handle the follow command & 3 line response from my device
R1
R1
WS=   ,WD=   ,RH=   ,AT=   ,RG=   ,SR=   ,BP=   ,S1=   ,S2=   ,BV=   ,LC=   ,SV=   ,CC=   ,9R=   ,Ev=
+000006.02,+000106.95,+000051.97,+000027.21,+000006.92,+000010.50,+000902.35,+000019.26,+000018.63,+000012.37,+000035.12,+000012.47,+000249.95,+000009.65,+000004.03
km/h   ,Degrees,%      ,Deg C  ,mm     ,W/m^2  ,hPa    ,Deg C  ,Deg C  ,V      ,mA     ,V      ,mA     ,mm     ,mm
The reason for using "> " for the input terminator is to handle a command prompt that the device sends without a CR LF. I then treat the 3 line response as a single line with "\r\n" in the format string. This worked quite well for the 20100615 snapshot but with the latest, I find that the last %*s before the \r\n also consumes the \r\n. So for the new snapshot I need to remove the 2nd "\r\n" in the format string. Not sure if this change was intentional or not. Other than that, works fine on Mac.
Regards
Craig
Craig Haskins
Software Engineer
Australia Telescope National Facility
CSIRO Astronomy and Space Science
P.O.Box 76, Epping NSW 1710, Australia
Phone: +61 2 9372 4309
email: [email protected]
Re: New StreamDevice version Craig.Haskins
RE: New StreamDevice version Craig.Haskins
Prev: RTEMS BSP for the KineticSystems VXI V152 PPC slot-0 Controller? Allison, Stephanie
Next: Re: question about aSubRecord wantianmin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: New StreamDevice version Craig.Haskins
Next: Re: New StreamDevice version Craig.Haskins
ANJ, 05 Dec 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
