1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: how to ignore debug message of streamDevice?
To: Ding Jianguo <[email protected]>
Cc: [email protected]
Date: Thu, 09 Dec 2010 10:37:36 +0100
Hello  Jianguo,
Even with streamDebug=0 the ioc still prints error messages, e.g. on
timeouts. These messages go to the console and to the log file.
But a log file is only created if  you do so in the main function of
your ioc. For example I have in streamAppMain.cc:
int main(int argc,char *argv[])
#ifdef DEBUGFILE
#define STR2(x) #x
#define STR(x) STR2(x)
    StreamDebugFile = fopen(STR(DEBUGFILE), "w");
#endif
    if(argc>=2) {
        iocsh(argv[1]);
        epicsThreadSleep(.2);
    iocsh(NULL);
    return(0);
When you compile it without DEBUGFILE being set it will not create the
file. Instead all messages only go to the console.
The macro is set in the example Makefile:
# Write StreamDevice debug output to this file
CPPFLAGS += -DDEBUGFILE=StreamDebug.log
Simply comment out this line.
Best regards,
Dirk
Ding Jianguo wrote:
> Hi, all
> I run epics with streamDevice+asynDriver on MOXA embeded computer
> DA-660(32M flash, 128M RAM). The IOC creats StreamDebug.log file to
> record error message of communication. Although I set streamDebug to 0,
> The log file still increases to MBs after IOC run for several days, thus
> make all free space exhausted. Is there any way to prevent all debug
> message from writing to the log file?
> Jianguo
> SSSRF,SINAP,CAS.
Prev: Re: Debugging EPICS with gdb Ernest L. Williams Jr.
Next: rtems-4.10 tftp support Jim Chen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Problem: Build EPICS 3.14.12 on windows 7 using Visual C++ 2010 Chen Xue
ANJ, 13 Dec 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
