1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RE: Base-3.14.12 (win32) on win 7 64 bit system
To: Brands Helge <[email protected]>
Cc: [email protected]
Date: Thu, 09 Dec 2010 16:56:25 -0600
Helge,
I think you are onto something.
The base-3.14.12 compiles if it is untared in the destination directry; however, it does NOT compile if it is untarred in different directory and then copied to the final directory (c:\epics\base-3.14.12).
I did not notice that problem before with base-3-14-11, so am not sure if it applies to that and prior versions of base. Is it indeed new to windows 7?
Where would I check the file rights /inheritance for windows 7. Can you elaborate (cacls or folder->properties ...)
Kaz,
----- Original Message -----
Date: Wednesday, December 8, 2010 3:04 am
Subject: RE: Base-3.14.12 (win32) on win 7 64 bit system
To: [email protected]
> Hi Kaz,
I have had the same problem. Check the rights of your files. Sometimes the files are marked only readable and not read and execute.
The file rights /inheritance has changed on win7 systems.
Helge
RE: Base-3.14.12 (win32) on win 7 64 bit system Brands Helge
Prev: Re: rtems-4.10 tftp support Daron Chabot
Next: Problem: Build EPICS 3.14.12 on windows 7 using Visual C++ 2010 Chen Xue
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Base-3.14.12 (win32) on win 7 64 bit system Brands Helge
Next: Debugging EPICS with gdb Bruce Hill
ANJ, 13 Dec 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
