1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Breakpoint Tables
To: David Dudley <[email protected]>, EPICS tech-talk <[email protected]>
Date: Thu, 16 Dec 2010 18:14:53 -0800
(1) Copy menuConvert.dbd from base/dbd to the app's src directory.
(2) In the src directory, create a breakpoint table file <bpname>.dbd.  Look at base/dbd/bpt*.dbd for the proper format.
(3) In your src/menuConvert.dbd, add a line for your new breakpoint table, using the breaktable name from the first line of <bpname>.dbd.   Look at the existing breakpoint table entries in menuConvert.dbd for the proper format.
(4a) If the breakpoint table is monotonic or epics base is < 3.14.9, add <bpname>.dbd to the app's dbd build in Makefile:
<appname>_DBD += <bpname>.dbd
(4b) If the breakpoint table is non-monotonic and epics base > 3.14.8, install <bpname>.dbd by itself in Makefile:
DBD += <bpname>.dbd
(5) Clean/build src.
(6) Use the breaktable name in the record's LINR field.
(7) If the breakpoint table is non-monotonic and epics base > 3.14.8, change st.cmd to set the non-monotonic flag and load the breakpoint table:
dbBptNotMonotonic=1  (rtems)
or
var dbBptNotMonotonic 1 (soft)
dbLoadRecords("dbd/<bpname>.dbd")
Stephanie Allison
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of David Dudley
> Sent: Thursday, December 16, 2010 1:59 PM
> To: EPICS tech-talk
> Subject: Breakpoint Tables
> I have 4 instruments that read differential pressure across V-Cone flowmeters.  The
> manufacturer supplied us with a 10-point calibration, which covers the desired engineering
> range.  These devices are not linear, and I think the right way to handle them is going to be
> to generate a breakpoint table for each (all 4 are sized differently).
> I'm looking through the app guide, section 6.17.  Is this the accepted method to generate a
> breakpoint table?  Since epics was installed through a package, I don't have the
> "menuConvert.dbd" file, so I'll have to download a source archive for that.  Now, it says to
> copy the menuConvert.dbd file, but it doesn't tell me where to put it.  In the source
> directory of the IOC application?
> Section 6.13 refers to a 'breaktable' command.  Is that an easier way to do this?
> How about a simple step-by-step description of how to generate a breakpoint table?
> David
> "... The Crossbow Project. There's No Defense Like a Good Offense. " - Real Genius (1985)
> Don't think it exists?  Google the Air Force X-37B project.
Re: Breakpoint Tables David Dudley
Prev: Breakpoint Tables David Dudley
Next: Re: Breakpoint Tables David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 16 Dec 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
