1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: 24-bit DAC
To: "'Eric Berryman'" <[email protected]>
Cc: [email protected]
Date: Fri, 17 Dec 2010 10:17:26 -0000
Eric,
Hytec have a new IP card, the 8515, it is 16 independent channels of 18 bit
DAC in Industry Pack format using TI DAC9881 chips. See attached.
This design could be modified to use the AD5791 20 bit DAC mentioned by
Yuke.
Graham Cross
Hytec Electronics Ltd.
>-----Original Message-----
>From: [email protected] [mailto:tech-talk-
>[email protected]] On Behalf Of Eric Berryman
>Sent: 16 December 2010 18:23
>To: [email protected]
>Subject: 24-bit DAC
>Hello!
>Does anyone know of/can recommend a 24-bit DAC (maybe something
>similar to the Acromag IP236A)?
>Google gave me the following, but it seems on the expensive side:
>http://www.freqdev.com/products/subassembly/vm8dac.html
>Thank you!
>Eric Berryman
Attachment: IP8515.pdf
Description: Adobe PDF document
24-bit DAC Eric Berryman
Prev: RE: 24-bit DAC austen.rose
Next: building latest snapshot of streamDevice Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: 24-bit DAC Graham Cross
ANJ, 17 Dec 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
