Because GnuWin32 has also link.exe, make.exe looks first from its current directoy and that overrides link.exe from VC.
Either rename it or remove it in case you dont GnuWin32 at all.
Best,
Xiaoqiang
-----Original Message-----
Sent: Fri 12/17/2010 9:14 PM
To: [email protected]
Subject: Build EPICS 3.14.12 in windows 7 by MS VC++ 2010 Express
I build the EPICS 3.14.12 in windows 7 OS. The software I used is as
below. After unzip the base 3.14.12, I modify the file, win32.bat in
base\startup\, to set the specific environment variable in my computer
and run it before build. The special things I found is when I made a
copy of gnu make "make.exe" file in the epics base folder. It builds
successfully. But without it, it has error message because it calls gnu
make link.exe instead of VC++ link.exe.
1. GNU Make (gnuwin32 v3.8.1)
2. ActivePerl 5.12
3. MS VS C++ 2010 Express
4. epics base 3.14.12
- Build EPICS 3.14.12 in windows 7 by MS VC++ 2010 Express Chen Xue
Re: Breakpoint Tables David Dudley
openmotif installtion problems. Saed Abu Ghannam
<2010>
2025
2026
Patch for EDM Crashes on x86_64 Sebastian Marsching
<2010>
2025
2026
