1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: About PCAS Access Control
To: 'åçä' <[email protected]>, "'tech-talk'" <[email protected]>
Date: Mon, 20 Dec 2010 11:03:01 -0700
Sorry about the delay responding , I took some âvacationâ time to set some tile in the basement of my house.
à Here is my question. I want to add  access control to my PCAS,
à but I do not  know what the pUserName and pHostName in the
à following function refer to clearly.
à virtual casChannel *createChannel ( const casCtx &ctx,const
à char * const pUserName,const char * const pHostName);
à
In the createChannel virtual member function the pUserName argument is a constant nill terminated string which is the user name of the user account the ca clientâs application is running under. In the createChannel virtual member function the pHostName argument is a constant nill terminated string which is the name (typically the dns name) of the host the ca clientâs application is running on.
à In "Channel Access Protable Server API Tutorial" it said
à that points to a string representing the user's name and  pHostName
à points to a string representing the server tool's host.
There might be a documentation issue here. It should say that it is the host name (typically the dns name) of the _clientâs_, and not the serverâs, host. I created bug entry 692664 at the epics launchpad site.
à
à For example, I have
à two EDM clients application run on the same linux PC, does the user's name
à refer to the PC name or something else.
The user name of the user account the client application runs on.
à William Lu wrote:
à Channel access security is better achieved by usnig the
à EPICS access security API. If you follow that path, at
à some point in your pcas code you will call
à asAddClient(&client, member, asl, pUserName, pHostName),
à to which you pass the pUserName and pHostName, as illustrated bellow:
Yes, this is the typical approach - which causes access security configuration of your service to be similar to, for example, an IOC or the ca gateway.
Jeff
______________________________________________________
Jeffrey O. Hill           Email    ÂÂÂ
[email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
From: [email protected] [mailto:[email protected]] On Behalf Of ???
Sent: Monday, December 13, 2010 7:54 PM
To: tech-talk
Subject: About PCAS Access Control
Hi all,
Here is my question. I want to add  access control to my PCAS, but I do not  know what the pUserName and pHostName in the following function refer to clearly.
virtual casChannel *createChannel ( const casCtx &ctx,const char * const pUserName,const char * const pHostName);
In "Channel Access Protable Server API Tutorial" it said that points to a string representing the user's name and  pHostName points to a string representing the server tool's host. For example, I have two EDM clients application run on the same linux PC, does the user's name refer to the PC name or something else.
I have implemented the createChannel function and  writeAccess function like this:
casChannel *exPV::createChannel ( const casCtx &ctx,
        const char * const  /*pUserName*/,
        const char * const  /*pHostName*/)
    return new exChannel ( ctx,"zhangyul","Administrator");
bool exChannel::writeAccess () const
      if (strcmp(User.string(), "zhangyul") == 0)
return aitFalse;
      else
return aitTrue;
However, I found that any client could not write the PCAS's PV, I think my understanding is totally wrong about user's name and the host name!!
Thank you!
Zhang Yuliang
About PCAS Access Control 张玉亮
Prev: epics under NET OS Yuriy Gorbunov
Next: RE: Problem: Build EPICS 3.14.12 on windows 7 using Visual C++ 2010 Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: About PCAS Access Control William Lu
Next: Controls Group vacancies Diamond Light Source mark.heron
ANJ, 20 Dec 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
