1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: record STAT = SCAN
To: [email protected]
Date: Tue, 4 Jan 2011 14:36:20 -0600
Hi John,
On Tuesday 04 January 2011 13:46:19 John Dobbins wrote:
> I have a record connected to hardware through device support that I have
> written. I have a situation in which the record ends up in the state STAT =
> SCAN, SEVR = INVALID
> I looked in dbAccess.c and it appears to me that this can mean that
> MAX_LOCK requests were made to process an already processing record. Is
> this correct?
Yup, if PACT is true for MAX_LOCK successive attempts to process the record it
will go into this state (but that won't stop the device support from running
the second half of record processing if it eventually tries that).
> I am guessing my device support is not finishing properly so that
> consecutive requests pile up. Is this a good guess?
Most likely.  The requests don't actually pile up though, they just get
counted, up to MAX_LOCK times, and immediately discarded.
> Apologies for the open ended nature of this query. Searching for "STAT"
> and "SCAN" can find a lot of not particularly helpful info.
Apologies that this was not better documented, I've added a bug against the
AppDevGuide which should at least have an index entry; SCAN_ALARM is mentioned
briefly in section 5.9.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
record STAT = SCAN John Dobbins
Prev: record STAT = SCAN John Dobbins
Next: APS Webserver Upgrade tomorrow Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
