1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MOXA terminal server
To: <[email protected]>
Cc: [email protected]
Date: Wed, 5 Jan 2011 17:20:05 +0000
Hi Dirk,
That's interesting.. which model of MOXA are you using?  I think the
6650 is Windows.
Emma
> -----Original Message-----
> From: Dirk Zimoch [mailto:[email protected]]
> Sent: 05 January 2011 15:59
> To: Shepherd, Emma (DLSLtd,RAL,DIA)
> Subject: Re: MOXA terminal server
> Hi Emma,
> Does your Moxa run on Linux or Windows? Mine is Linux and I use the
> local program /bin/setinterface to select the mode (RS232, RS482 2
> wire,
> RS422, RS485 4 wire).
> When running EPICS on the Moxa, you can do this from the EPICS startup
> script with the 'system' command (3.14.12) or from inside StreamDevice
> with the 'exec' command.
> Dirk
> [email protected] wrote:
> > Hi all,
> > We have recently been investigating options for controlling serial
> > devices via a terminal server.  We particularly want the ability to
> > software switch between RS-232/RS-422/RS-485.  One that has this
> > capability and seems to be generally recommended by the EPICS
> community
> > is the MOXA NP6650 32-port device server.
> > However, after buying one to evaluate, we discovered an annoying
> > 'feature': to change the settings of a serial port over the web
> > interface (baud rate etc) requires a reboot of the server, which of
> > course disrupts communications on all ports (and actually crashes my
> > soft IOC, though this might be a streamDevice issue...).
> > We wondered if anybody else has also come across this problem?  If
so
> > have you found a way of getting around it, or do you have any other
> > recommendations?  I have contacted MOXA technical support about the
> > issue, but they don't seem prepared to fix it.
> > Thanks in advance,
> > Emma
Re: MOXA terminal server Eric Norum
Re: MOXA terminal server Dirk Zimoch
MOXA terminal server emma.shepherd
Prev: how often do you use Tornado IDE tools for vxworks programming 王林
Next: Re: MOXA terminal server Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: MOXA terminal server Dirk Zimoch
