1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: pyepics callback function problem
To: [email protected]
Date: Thu, 06 Jan 2011 11:52:30 +0100
Hello
I hope this is a right place to ask a question about pyepics.
I want to monitor two epic variables in a Python script. Interactive session gives this printout:
In [1]: import epics
In [2]: epics.__version__
Out[2]: '3.0.10'
In [5]: pll = epics.PV('LUCA:ENV:ENV_SC_PLL_MONITOR')
In [6]: print pll.info
== LUCA:ENV:ENV_SC_PLL_MONITOR  (native_enum) ==
  value      = 1
  char_value = 'LOCKED'
  count      = 1
  type       = enum
  host       = 10.0.4.51:5064
  access     = read/write
  status     = 0
  severity   = 0
  timestamp  = 1294304943.721 (2011-01-06 10:09:03.721306)
  enum strings:
      0 = UNLOCKED
      1 = LOCKED
  PV is internally monitored, with 0 user-defined callbacks:
In [16]: ventilator = epics.PV('LUCA:ENV:ENV_FRONT_VENT_ACT_MONITOR')
In [17]: print ventilator.info
== LUCA:ENV:ENV_FRONT_VENT_ACT_MONITOR  (native_double) ==
  value      = 4230
  char_value = '4230'
  count      = 1
  type       = double
  units      = RPM
  precision  = 0
  access     = read/write
  status     = 0
  severity   = 0
  timestamp  = 1294306643.047 (2011-01-06 10:37:23.046888)
  upper_ctrl_limit    = 0.0
  lower_ctrl_limit    = 0.0
  upper_disp_limit    = 0.0
  lower_disp_limit    = 0.0
  upper_alarm_limit   = 0.0
  lower_alarm_limit   = 0.0
  upper_warning_limit = 5500.0
  lower_warning_limit = 2000.0
So I have two varibles, one of enum type and one of double type with unit defined. They both change very slowly.
I wrote a simple program to monitor their value:
import sys
import time
from epics import PV
def callback_function(pvname=None, value=None, char_value=None, type=None,units=None, enum_strs=None, **kw):
   print "------Printout from callback ------"
   fmt = ' pvname \t = %s \n value \t\t = %s \n\
char_value \t = %s \n type \t\t = %s \n\
units \t\t = %s \n enum_strs \t = %s \n'
   print fmt % (pvname, value, char_value, type, units, enum_strs)
   print "----------------------------------\n"
pll = PV('LUCA:ENV:ENV_SC_PLL_MONITOR')
vent = PV('LUCA:ENV:ENV_FRONT_VENT_ACT_MONITOR')
pll.add_callback(callback_function)
pll.run_callbacks()
vent.add_callback(callback_function)
vent.run_callbacks()
while True:
   time.sleep(0.001)
But the results are strange :
pvname      = LUCA:ENV:ENV_SC_PLL_MONITOR
value          = 1
char_value      = 1
type          = enum
units          = None
enum_strs      = None
pvname      = LUCA:ENV:ENV_FRONT_VENT_ACT_MONITOR
value          = 4260.0
char_value      = 4260.0
type          = double
units          = None
enum_strs      = None
The problem is that only value, pvname and type is passed properly. char_value for pll varibale (enum type) should be LOCKED , also enum_strs shold be defined, and there is no units for vent variable.
Is this a bug  or am I doing something wrong ?
Best regards,
                 Janko Kolar
Re: pyepics callback function problem Matt Newville
Prev: Re: MOXA terminal server Dirk Zimoch
Next: Test, please ignore Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: UKIRT's Allen Bradley temperature problem - solved Maren Purves
Next: Re: pyepics callback function problem Matt Newville
