1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CSS Data Browser Plot Problem
To: John Dobbins <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Fri, 07 Jan 2011 14:45:54 -0500
Hi:
On 1/7/11 14:22 , "John Dobbins" <[email protected]> wrote:
> We have encountered a case in which CSS Data Browser does not
> display a PV correctly. It can export the data (so has certainly
> retrieved it from the Archiver).
Yes, but in different ways.
> # Created by CSS Data Browser Version 2.0.5.20101112
> # Start Time : 2010/11/16 20:45:00.000000000
> # End Time   : 2010/11/16 20:46:00.000000000
> # Source     : Optimized Archived Data
> # Desired Value Count: 1000
The export process itself requested ~1000 samples between start & end time.
The plot uses a desired value count that's configured in the under
preferences CSS/Apps/Trends/Data Browser, by default 800.
Check in the Sample view to see what data the plot actually has to determine
if the problem is in the data that the plot uses, or the plot itself.
If this is for the old Channel Archiver with the XML-RPC network data
server, you can also check the log file of the network data server
(/tmp/archserver.log) to compare
a) What the plot requests & gets
b) What the export requests & gets
I assume the reason lies in the way the data is requested, and how that's
handled by the XML-RPC network data server.
What version is your XML-RPC network data server?
Kay
Re: CSS Data Browser Plot Problem John Dobbins
Prev: CSS Data Browser Plot Problem John Dobbins
Next: Re: CSS Data Browser Plot Problem John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
