1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Andor driver for areaDetector?
To: <[email protected]>, <[email protected]>
Date: Mon, 10 Jan 2011 12:17:31 +0000
Hi Mark,
Yes, I wrote one using areaDetector 1-4 and asyn 4-10 for the iKon CCD.
It uses a USB interface.
So it needs updating, and there are a few features I'd like to add
before I consider it finished. But the I16 beamline at Diamond have been
using it routinely for about a year.
I can send you a tar file of what I have.
It works on RHEL5 with no problems (but didn't work on RHEL4).
Features:
Trigger readout and save files in TIFF.
Change between internal software trigger and external trigger.
Set and read the exposure time.
Set and read the filename/path.
Set and read temperature of CCD.
Control the internal shutter, and the opening time.
Set and read the CCD readout rate (for low noise operation).
Basic GUI.
The software depends on an install script from Andor that needs to be
run as root. It installs a shared library in /usr/lib/ and USB udev
scripts.
Cheers,
Matt
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Mark Rivers
> Sent: 14 December 2010 19:54
> To: [email protected]
> Subject: Andor driver for areaDetector?
> Has anyone written an areaDetector driver for Andor CCD detectors?
> Thanks,
> Mark
RE: Andor driver for areaDetector? Mark Rivers
Prev: RE: CSS Data Browser Plot Problem Kasemir, Kay
Next: RE: 24-bit DAC matthew.pearson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: streamDevice I/O Intr polling rate Dirk Zimoch
Next: RE: Andor driver for areaDetector? Mark Rivers
