1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Access to records from subroutines during iocInit
To: "Allison, Stephanie" <[email protected]>
Date: Thu, 13 Jan 2011 13:47:45 -0800
Thanks, Stephanie.  That did the trick.
   ---   rod.
Allison, Stephanie wrote:
Hi Rod,
The INIT (INAM) subroutine is called during the database record initialization part of iocInit:
http://www.aps.anl.gov/epics/base/R3-14/12-docs/AppDevGuide/node8.html#SECTION00840000000000000000
The INAM routine is only meant to be used to allocate memory and any other resources or system initialization needed by the processing (SNAM) subroutine.
The IOC is not yet ready for ANY record processing so your dbPutField fails.
Instead, you need to process during the initial processing part of iocInit (aka when PINI=YES processing is done) which comes a little later.  This processing will still be done before any EDM client connects to the waveform so should meet your requirement.  So move the dbPutField to the processing subroutine and set PINI=YES.  I assume SCAN=Passive so it'll only process once.
Stephanie Allison
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf
Of Rod Nussbaumer
Sent: Thursday, January 13, 2011 9:27 AM
To: [email protected]
Subject: Access to records from subroutines during iocInit
Hi All.
I have a question/problem, which may simply be me trying to work outside
the expected norms. It involves writing to records during IOC
initialization. I will give a summary of the situation:
A subroutine record has on one of its inputs, a link to a waveform
record. During the INIT subroutine, I call dbGetPdbAddrFromLink() to
locate the waveform record, as well as call dbGetNelements() to find the
size of the respective waveform record. This seems to work.
My intention is to initialize the waveform record with data
algorithmically created. I do this by creating an array, and calling
dbPutField(), using the value saved from the earlier call to
dbGetPdbAddrFromLink(). This results in the following:
A call to 'assert(dbLockIsInitialized)'
      by thread '_main_' failed in ../dbLock.c line 239.
EPICS Release EPICS R3.14.11 $R3-14-11$ $2009/08/28 18:47:36$.
Local time is 2011-01-13 09:05:45.332489000 PST
Please E-mail this message to the author or to [email protected]
Calling epicsThreadSuspendSelf()
If I perform the same actions within the PROC subroutine of the
subroutine record, it seems to work as I expected it to. So, if this is
not a bug, is there a proper way to accomplish what I am attempting?
There are no other records referencing or linked to the waveform record.
Its data is used purely for visualization purposes in an EDM X-Y Graph.
Thanks for listening.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada.
Access to records from subroutines during iocInit Rod Nussbaumer
RE: Access to records from subroutines during iocInit Allison, Stephanie
Prev: Re: MOXA terminal server Eric Norum
Next: sscan and averaging [SEC=UNCLASSIFIED] LYNCH, Damien
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Access to records from subroutines during iocInit Allison, Stephanie
