Folks,
asyn R4-16 is now available. Links to the new documentation, release notes and tar file can be found here:
http://www.aps.anl.gov/epics/modules/soft/asyn/
asyn is now also available via the APS Subversion repository here:
https://svn.aps.anl.gov/epics/asyn/
This is from the release notes:
drvAsynIPPort
Support has been added for terminal servers which support the TELNET RFC 2217 protocol. To communicate with such devices specify "COM" as the protocol in the drvAsynIPPortConfigure command. This allows port parameters (speed, parity, etc.) to be set using an asynRecord or asynSetOption commands just as for local serial ports.
drvVxi11
Fix from Benjamin Franksen to fix problem with reconnection.
The 'timeout' argument to vxi11Configure has been changed from double to string. This allows vxi11Configure to be called directly from the vxWorks shell.
GigE driver for Area Detector tom.cobb
StreamDevice/ASYN connection to a Telnet port John Dobbins
<2011>
2025
2026
Re: GigE driver for Area Detector Eric Norum
<2011>
2025
2026
