1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Changing DOL field from a subroutine record
Date: Wed, 19 Jan 2011 13:27:24 -0800
I'd like to change the DOL field from an genSubRecord. The OUT field that points to the DOL to type "STRING".
I populate the string, with a generated PV name or an empty string, and let the genSub record do the dbPutLink
Which outputs the error.
Illegal Database Request Type PV: TRIG:B34:215:RULE7_TCTL.DOL error detected in routine: dbPut - database request type is 0
Illegal Database Request Type PV: TRIG:B34:215:RULE7_TDES.DOL error detected in routine: dbPut - database request type is 0
I can do dbpf() from the console port to change a DOL field, so is there a reason why dbPutLink can't or am
I just using this incorrectly? Any suggestions?
- Kristi
Re: Changing DOL field from a subroutine record Andrew Johnson
Prev: RE: Problem exiting IOC Jeff Hill
Next: debian repository key change Davidsaver, Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Problem exiting IOC Vigder, Mark
Next: Re: Changing DOL field from a subroutine record Andrew Johnson
