On Monday 24 January 2011 13:04:20 [email protected] wrote:
> On 03:48 Sat 22 Jan, Matthieu Bec wrote:
> > I think your routine needs to return 0 on success to push the values out
> Yes, that fixed the problem.
> With gensub I used counter to keep tracks of how many times the record was
> called. For gensub records, the returned value was assigned to the record.
For aSub records the value returned by the subroutine is an error status; if
it returns a negative number the record goes into SOFT_ALARM with severity
controlled by the BRSV field. Positive but non-zero status values do not
result in an alarm, but they do disable pushing the OUTx links.
> Q: Is there a way to change the value of the asub record?
The VAL field is set to the return status of the subroutine, but it only
pushes the VALx field values through their OUTx links if that status is zero
(OK). You'll want to use a different VALx field to hold your counter.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it. If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence. -- Bertrand Russell
- gensub to asub emmanuel_mayssat
- Re: gensub to asub Matthieu Bec
- Re: gensub to asub emmanuel_mayssat
gensub/asub inputs not PP Till Straumann
<2011>
2025
2026
Driver for ABC 1260 Neutron Detector / Dosimeter from Framework Scientific Bryce Karnaghan
<2011>
2025
2026
