1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: gensub/asub inputs not PP
To: Till Straumann <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Tue, 25 Jan 2011 14:06:53 +0000 (GMT)
Hi Till,
Originally, there were only A-J input fields in the genSub
and the idea was that you would set-up all the input fields
with values and then make the record process by writing to
what was then then the last field. I didn't want to make
it process before I had set-up all the fields.
Cheers,
Andy
On Mon, 24 Jan 2011, Till Straumann wrote:
> I saw that - in contrast to good old subRecord - the
> various input fields (A..U) of aSub or genSub
> do not have the pp(TRUE) attribute, i.e., when I
> change one of these inputs the record is not processed
> (if passive).
> As a curiosity, the genSub record had just input
> field J with pp(TRUE).
> Can someone enlighten me why these records were
> designed this way? It would seem more useful to me
> that when I write to an input field the record
> should process.
> - Till
gensub/asub inputs not PP Till Straumann
Prev: CSS BOY Meter widget limits Paweł Prędki
Next: Re: CSS BOY Meter widget limits Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: gensub/asub inputs not PP Till Straumann
Next: bo Record not forcing VAL to 0 or 1 Bruce Hill
