1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: epicsEvent (posix implementation) bug ?
To: <[email protected]>
Cc: [email protected]
Date: Mon, 31 Jan 2011 17:59:52 +0000
For my particular application I do require priority scheduling of multiple writers on PREEMPT_RT Linux. As Till mentioned moving to a single pthread condition variable per queue empty/full would give this (depending on the scheduling policy) and also remove the need for dynamic memory allocation in the implementation, whether this is a desirable default semantics for Linux is another matter. I would say yes.
Sent: 31 January 2011 16:13
To: Rowland, James (DLSLtd,RAL,DIA)
Cc: EPICS Tech Talk
Subject: Re: epicsEvent (posix implementation) bug ?
Are you suggesting that we require priority-based queueing for multiple readers?  At the moment the appDevGuide does not specify this requirement, though as you point out, non-priority queueing can lead to priority inversion.  The current vxWorks and RTEMS implementations provide FIFO queueing but it would be a one-word change to get them provide priority queueing.  Not sure about windows, but since priority inversion is a major issue only for systems with strict priority-based scheduling I'm not sure that it's that big a deal there anyhow.
On Jan 31, 2011, at 1:16 AM, <[email protected]> wrote:
Removing the thread wakeup FIFO and sharing the wakeup event is
essential for correct scheduling behaviour otherwise a low priority
thread can block a high priority thread on a message queue read even
with priority inheritance enabled. EpicsEvent will also need patching to
enable PTHREAD_PRIO_INHERIT, the code is present in EpicsMutex but
EpicsEvent initializes a pthread_mutex directly. I'll nominate this as a
job for the codeathon.
Eric Norum
[email protected]
epicsEvent (posix implementation) bug ? Till Straumann
RE: epicsEvent (posix implementation) bug ? james.rowland
Re: epicsEvent (posix implementation) bug ? Eric Norum
Prev: Re: epicsEvent (posix implementation) bug ? Till Straumann
Next: Re: ca_create_channel memory management Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: epicsEvent (posix implementation) bug ? Andrew Johnson
