1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: StreamDevice/ASYN connection to a Telnet port
To: Eric Norum <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 2 Feb 2011 11:56:01 -0500
FWIW, I also see similar one-char-at-a-time behavior from a Pfeiffer Maxigauge TPG-256-A. This is using the serial interface on the gauge-controller through a moxa 5650 terminal server.
We are using 3.14.11 with the asyn and streamdevice version as distributed in synapps 5.5.
On Wed, Feb 2, 2011 at 11:06 AM, Eric Norum <[email protected]> wrote:
I think that this is the result of the device (stupidly and inefficiently) sending one character per IP packet.
On Feb 2, 2011, at 7:30 AM, Dirk Zimoch wrote:
> Hi John,
> StreamDevice normally reads first a single byte and then the rest in chunks of up to 63 bytes. The reason is that the first byte uses a different timeout (ReplyTimeout) than the others (ReadTimeout). The rest is fetched in 63 bytes chunks because I use an internal buffer of 64 bytes and want to be able to add a null byte at the end to avoid problems with some debug output.
> So the first "read 1" is normal. What surprises me are the other lines.
> When you switch on debugging in StreamDevice (var streamDebug 1), what do you see?
> Dirk
> John Dobbins wrote:
>> Dear All,
>> I am connecting to a Gamma Vacuum SPCe ion pump power supply. This device has an ethernet port which accepts telnet connections.
>> I set up StremDevice to communicate with it on port 23,
>> I have  asyn Trace Masks set as follows:
>> asynSetTraceMask("SPCe",-1,0x09)
>> asynSetTraceIOMask("SPCe",-1,0x2
>> I have a problem in that the response string , which I expect to look like  "OK 00 7.90E-13 TORR" appears like this:
>> epics> 2011/01/17 16:14:55.995 172.18.32.21:23 write 7
>> spc 0B\r
>> 2011/01/17 16:14:56.475 172.18.32.21:23 read 1
>> O
>> K
>> 0
>> 0
>> 2011/01/17 16:14:56.476 172.18.32.21:23 read 1
>> 7
>> 9
>> 2011/01/17 16:14:56.477 172.18.32.21:23 read 1
>> 0
>> E
>> 1
>> 2011/01/17 16:14:56.478 172.18.32.21:23 read 1
>> 3
>> T
>> O
>> R
>> 2011/01/17 16:14:56.479 172.18.32.21:23 read 1
>> R
>> \r
>> Can someone tell me what is going on here?
>> Regards and thanks,
>> John Dobbins
>> Cornell University
>> Lab for Elementary Particle Physics
Eric Norum
[email protected]
StreamDevice/ASYN connection to a Telnet port John Dobbins
Re: StreamDevice/ASYN connection to a Telnet port Dirk Zimoch
Re: StreamDevice/ASYN connection to a Telnet port Eric Norum
Prev: Re: StreamDevice/ASYN connection to a Telnet port John Dobbins
Next: Trouble with mcaR6-12-4 and EPICS 3.14.12 (cygwin-x86) Carl Willis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: StreamDevice/ASYN connection to a Telnet port Eric Norum
Next: Re: StreamDevice/ASYN connection to a Telnet port John Dobbins
