1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epics 3.14.12 and readline 5.1
To: Matt Rippa <[email protected]>
Date: Wed, 2 Feb 2011 11:57:08 -0800
You need to link agains the ncurses library too.
In CONFIG_SITE.Common.linux-x86 (or CONFIG_SITE.Common.linux-x86_64 as appropriate) uncomment the line that gets NCURSES:
# No other libraries needed (recent Fedora, Ubuntu etc.):
#COMMANDLINE_LIBRARY = READLINE
# Needs -lncurses (RHEL 5 etc.):
COMMANDLINE_LIBRARY = READLINE_NCURSES
# Needs -lcurses (older versions)
#COMMANDLINE_LIBRARY = READLINE_CURSES
On Feb 2, 2011, at 11:48 AM, Matt Rippa wrote:
> Hi Folks,
> Sorry if this has come up before. I couldn't find anything
> searching tech-talk. I'm trying to build epics-base 3.14.12 on
> RHEL5. The build fails when I enable
> COMMANDLINE_LIBRARY=READLINE in
> configure/os/CONFIG_SITE.Common.linux-x86.  The build works fine
> when I comment this line out.
> $ rpm -q readline
> readline-5.1-3.el5
> $ rpm -q readline-devel
> readline-devel-5.1-3.el5
> $ uname -a
> Linux hbfcon03.hi.gemini.edu 2.6.18-194.el5PAE #1 SMP Tue Mar 16
> 22:00:21 EDT 2010 i686 i686 i386 GNU/Linux
> FWIW, this compiles with readline just fine on my f13 laptop: ($
> rpm -q readline readline-6.1-2.fc13.i686).
> Thanks,
> Matt Rippa
> /usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE
> -Dlinux  -D_REENTRANT   -O3   -Wall      -m32     -g  -MMD -I.
> -I../O.Common -I. -I.. -I../../../../include/os/Linux
> -I../../../../include        ../warshall.c
> /usr/bin/g++ -o antelope
> -L/export/home/software/base-3.14.12-new/lib/linux-x86
> -Wl,-rpath,/export/home/software/base-3.14.12-new/lib/linux-x86
>      -m32                closure.o error.o lalr.o lr0.o main.o
> mkpar.o output.o reader.o skeleton.o symtab.o verbose.o
> warshall.o   -lCom
> /usr/lib/libreadline.so.5: undefined reference to `PC'
> /usr/lib/libreadline.so.5: undefined reference to `tgetflag'
> /usr/lib/libreadline.so.5: undefined reference to `tgetent'
> /usr/lib/libreadline.so.5: undefined reference to `UP'
> /usr/lib/libreadline.so.5: undefined reference to `tputs'
> /usr/lib/libreadline.so.5: undefined reference to `tgoto'
> /usr/lib/libreadline.so.5: undefined reference to `tgetnum'
> /usr/lib/libreadline.so.5: undefined reference to `BC'
> /usr/lib/libreadline.so.5: undefined reference to `tgetstr'
> collect2: ld returned 1 exit status
> make[4]: *** [antelope] Error 1
> make[4]: Leaving directory
> `/export/home/software/base-3.14.12-new/src/toolsComm/antelope/O.linux-x86'
> make[3]: *** [install.linux-x86] Error 2
> make[3]: Leaving directory
> `/export/home/software/base-3.14.12-new/src/toolsComm/antelope'
> make[2]: *** [antelope.install] Error 2
> make[2]: Leaving directory
> `/export/home/software/base-3.14.12-new/src/toolsComm'
> make[1]: *** [toolsComm.install] Error 2
> make[1]: Leaving directory
> `/export/home/software/base-3.14.12-new/src'
> make: *** [src.install] Error 2
Eric Norum
[email protected]
Re: epics 3.14.12 and readline 5.1 Matt Rippa
Prev: epics 3.14.12 and readline 5.1 Matt Rippa
Next: Re: epics 3.14.12 and readline 5.1 Matt Rippa
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
