1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: MEDM build problem
To: [email protected]
Date: Mon, 07 Feb 2011 15:34:21 -0600
Hi, everyone,
I'm new to MEDM. I'm trying to build MEDM in my Debian squeeze.  I have downloaded and installed libmotif-dev_2.3.3-5_i386.deb, libmotif4_2.3.3-5_i386.deb and motif-client_2.3.3-5_i386.deb (I'm not sure if I need all of these). The X11 comes with Debian squeeze package and I installed some other packages. Then I downloaded and unpack MEDM_3.1.4 in a <TOP> directory. When I build MEDM under <TOP>/src/medm, the error message is as below.
Could you please help me?
Many thanks,
Chen
make -C ./printUtils install
make[1]: Entering directory `/opt/epics/extensions/src/medm3_1_4/printUtils'
make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install
make[2]: Entering directory `/opt/epics/extensions/src/medm3_1_4/printUtils/O.linux-x86'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `/opt/epics/extensions/src/medm3_1_4/printUtils/O.linux-x86'
make[1]: Leaving directory `/opt/epics/extensions/src/medm3_1_4/printUtils'
make -C ./xc install
make[1]: Entering directory `/opt/epics/extensions/src/medm3_1_4/xc'
make[2]: Entering directory `/opt/epics/extensions/src/medm3_1_4/xc/O.linux-x86'
make[2]: Leaving directory `/opt/epics/extensions/src/medm3_1_4/xc/O.linux-x86'
make[1]: Leaving directory `/opt/epics/extensions/src/medm3_1_4/xc'
make -C ./medm install
make[1]: Entering directory `/opt/epics/extensions/src/medm3_1_4/medm'
make[2]: Entering directory `/opt/epics/extensions/src/medm3_1_4/medm/O.linux-x86'
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medm.c
../medm.c: In function ‘buildMenu’:
../medm.c:2764: warning: ‘cascade’ may be used uninitialized in this function
../medm.c: In function ‘main’:
../medm.c:3025: warning: ‘index’ may be used uninitialized in this function
../medm.c:3042: warning: ‘msgClass’ may be used uninitialized in this function
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmArc.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmBar.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmByte.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmChoiceButtons.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmCommon.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmComposite.c
../medmComposite.c: In function ‘compositeFileParse’:
../medmComposite.c:631: warning: the address of ‘filename’ will always evaluate as ‘true’
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmControl.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmDisplay.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmImage.c
../medmImage.c: In function ‘executeDlImage’:
../medmImage.c:82: warning: ‘gif’ may be used uninitialized in this function
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmIndicator.c
../medmIndicator.c: In function ‘indicatorUpdateGraphicalInfoCb’:
../medmIndicator.c:296: warning: ‘hopr’ may be used uninitialized in this function
../medmIndicator.c:297: warning: ‘precision’ may be used uninitialized in this function
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmMenu.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmMessageButton.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmMeter.c
../medmMeter.c: In function ‘meterUpdateGraphicalInfoCb’:
../medmMeter.c:271: warning: ‘hopr’ may be used uninitialized in this function
../medmMeter.c:272: warning: ‘precision’ may be used uninitialized in this function
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmMonitor.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmOval.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmPixmap.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmPolygon.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmPolyline.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmRectangle.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmRelatedDisplay.c
../medmRelatedDisplay.c: In function ‘executeDlRelatedDisplay’:
../medmRelatedDisplay.c:472: warning: ‘usedWidth’ may be used uninitialized in this function
../medmRelatedDisplay.c:472: warning: ‘usedHeight’ may be used uninitialized in this function
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmShellCommand.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmStripChart.c
../medmStripChart.c: In function ‘stripChartDialogCb’:
../medmStripChart.c:2623: warning: ‘button’ may be used uninitialized in this function
../medmStripChart.c: In function ‘stripChartUpdateGraphicalInfoCb’:
../medmStripChart.c:1188: warning: ‘hopr’ may be used uninitialized in this function
../medmStripChart.c:1189: warning: ‘precision’ may be used uninitialized in this function
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmText.c
../medmText.c: In function ‘drawText’:
../medmText.c:66: warning: ‘x’ may be used uninitialized in this function
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmTextEntry.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmTextUpdate.c
../medmTextUpdate.c: In function ‘textUpdateDraw’:
../medmTextUpdate.c:420: warning: ‘y’ may be used uninitialized in this function
../medmTextUpdate.c:420: warning: ‘x’ may be used uninitialized in this function
../medmTextUpdate.c:229: warning: ‘isNumber’ may be used uninitialized in this function
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmValuator.c
../medmValuator.c: In function ‘valuatorRedrawValue’:
../medmValuator.c:862: warning: ‘startX’ may be used uninitialized in this function
../medmValuator.c:862: warning: ‘startY’ may be used uninitialized in this function
../medmValuator.c:869: warning: ‘x’ may be used uninitialized in this function
../medmValuator.c:869: warning: ‘y’ may be used uninitialized in this function
../medmValuator.c:869: warning: ‘height’ may be used uninitialized in this function
../medmValuator.c:869: warning: ‘width’ may be used uninitialized in this function
../medmValuator.c: In function ‘valuatorUpdateGraphicalInfoCb’:
../medmValuator.c:531: warning: ‘hopr’ may be used uninitialized in this function
../medmValuator.c:532: warning: ‘precision’ may be used uninitialized in this function
../medmValuator.c: In function ‘createValuatorEditInstance’:
../medmValuator.c:297: warning: ‘heightDivisor’ may be used uninitialized in this function
../medmValuator.c:297: warning: ‘scalePopupBorder’ may be used uninitialized in this function
../medmValuator.c: In function ‘handleValuatorExpose’:
../medmValuator.c:622: warning: ‘lower’ may be used uninitialized in this function
../medmValuator.c:622: warning: ‘upper’ may be used uninitialized in this function
../medmValuator.c:610: warning: ‘pv’ may be used uninitialized in this function
../medmValuator.c: In function ‘createValuatorRunTimeInstance’:
../medmValuator.c:128: warning: ‘heightDivisor’ may be used uninitialized in this function
../medmValuator.c:128: warning: ‘scalePopupBorder’ may be used uninitialized in this function
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmWheelSwitch.c
../medmWheelSwitch.c: In function ‘wheelSwitchUpdateGraphicalInfoCb’:
../medmWheelSwitch.c:419: warning: ‘precision’ may be used uninitialized in this function
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../medmWidget.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../objectPalette.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../productDescriptionShell.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../resourcePalette.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../updateMonitors.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../updateTask.c
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../utils.c
../utils.c: In function ‘parseAndExecCommand’:
../utils.c:4288: warning: the address of ‘command’ will always evaluate as ‘true’
../utils.c: In function ‘generateNameValueTable’:
../utils.c:3175: warning: ‘tableIndex’ may be used uninitialized in this function
../utils.c: In function ‘sizeSelectedTextElements’:
../utils.c:2986: warning: ‘xOffset’ may be used uninitialized in this function
../utils.c: In function ‘centerSelectedElements’:
../utils.c:2906: warning: ‘xOffset’ may be used uninitialized in this function
../utils.c:2906: warning: ‘yOffset’ may be used uninitialized in this function
../utils.c: In function ‘alignSelectedElements’:
../utils.c:2254: warning: ‘xOffset’ may be used uninitialized in this function
../utils.c:2254: warning: ‘yOffset’ may be used uninitialized in this function
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32     -g  -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include -I../../../../../base-3.14.12/include/os/Linux -I../../../../../base-3.14.12/include        -I../../printUtils -I../../xc -I/usr/include -I/usr/include/X11   ../xgif.c
../xgif.c: In function ‘loadGIF’:
../xgif.c:721: warning: the address of ‘fullPathName’ will always evaluate as ‘true’
/usr/bin/g++ -o medm  -L/opt/epics/base-3.14.12/lib/linux-x86 -L/opt/epics/extensions/lib/linux-x86 -L/usr/lib -Wl,-rpath,/opt/epics/base-3.14.12/lib/linux-x86 -Wl,-rpath,/opt/epics/extensions/lib/linux-x86 -Wl,-rpath,/usr/lib       -m32                medmCartesianPlot.o medmSciPlot.o SciPlot.o medmCA.o actions.o bubbleHelp.o callbacks.o browserHelp.o channelPalette.o colorPalette.o dialogs.o display.o eventHandlers.o help.o medm.o medmArc.o medmBar.o medmByte.o medmChoiceButtons.o medmCommon.o medmComposite.o medmControl.o medmDisplay.o medmImage.o medmIndicator.o medmMenu.o medmMessageButton.o medmMeter.o medmMonitor.o medmOval.o medmPixmap.o medmPolygon.o medmPolyline.o medmRectangle.o medmRelatedDisplay.o medmShellCommand.o medmStripChart.o medmText.o medmTextEntry.o medmTextUpdate.o medmValuator.o medmWheelSwitch.o medmWidget.o objectPalette.o productDescriptionShell.o resourcePalette.o updateMonitors.o updateTask.o utils.o xgif.o   -lANLwidgets -lPrintUtils -lca -lCom -lXm -lXt -lXp -lXmu -lX11 -lXext   -lpthread   -lreadline -lm -lrt -ldl -lgcc
/usr/bin/ld: cannot find -lXp
collect2: ld returned 1 exit status
make[2]: *** [medm] Error 1
make[2]: Leaving directory `/opt/epics/extensions/src/medm3_1_4/medm/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `/opt/epics/extensions/src/medm3_1_4/medm'
make: *** [medm.install] Error 2
Re: MEDM build problem J. Lewis Muir
Re: MEDM build problem ZY (Zhijian Yin)
Prev: devlib2.1 Davidsaver, Michael
Next: Re: StreamDevice/ASYN connection to a Telnet port Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: MEDM build problem J. Lewis Muir
