Hello Xiaoqiang,
These messages occur because the IOC's windows OS process is exiting when
some of the ca server threads remain running. When the winsock facility is
abruptly terminated these threads receive error status returns from their
windows socket calls, and they therefore print diagnostic messages. You can
interpret these messages to be benign if they occur only when the windows
IOC is exiting. The differences between R3.14.12 and earlier releases might
have to do with subtle changes in the execution order of the various threads
as the windows process is abruptly removed from the system.
Nevertheless, we recognize that there is a root problem; currently the EPICS
IOC lacks an orderly shutdown. The new ca server definitely has an orderly
shutdown and we will arrange for this shutdown to be called in the future
when the IOC exits.
Sorry about the confusion,
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Wang Xiaoqiang
> Sent: Tuesday, February 08, 2011 7:15 AM
> To: [email protected]
> Subject: ioc exits with error on EPICS 3.14.12 win32-x86 host
> Hi,
> I have a unmodified EPICS 3.14.12 built with VS2008. I load a simple
> database with softIOC:
> record (ao, "ao")
> It works fine and only upon exit it gives the error:
> CAS: Client accept error was "WINSOCK Error 10004"
> CA cast server: Unable to fetch N characters pending
> CAS: UDP recv error (errno=WINSOCK Error 10093)
> ..\online_notify.c: CA beacon routing (connect to
> "129.129.144.83:5065") error was "WINSOCK Error 10093"
> The problem is also there when built with MinGW GCC. While it is OK with
> EPICS 3.14.11 and earlier.
> Best
> Xiaoqiang
- ioc exits with error on EPICS 3.14.12 win32-x86 host Wang Xiaoqiang
CA Lab with user events now! Carsten Winkler (HZB)
<2011>
2025
2026
<2011>
2025
2026
