1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: no envPaths in application of base 3.14.11
To: [email protected]
Date: Tue, 15 Feb 2011 09:42:24 -0600
On Monday 14 February 2011 23:57:52 Mi Qingru wrote:
>     I built an application with the example template from base 3.14.11.
>     There isn’t envPaths in iocBoot after ‘make’.
The envPaths file is created in the iocBoot/iocmyapps directory, can you
please confirm whether it is or is not present there?
If you read some documentation that implied it would appear directly in the
iocBoot directory would you please tell us where you read it, as it needs to
be corrected.
>     No error happened in compiling. Only:
>     make[2]: Entering directory ‘.../apps-11/iocBoot/iocmyapps’
>     make[2]: Nothing to be done for ‘install’
>     make[2]: Leaving directory  ‘.../apps-11/iocBoot/iocmyapps’
>     The Makefile in iocBoot/iocmyapps :
>     TOP=../..
>     include $(TOP)/configure/CONFIG
>     ARCH=linux-x86
>     TARGETS=envPaths
>     include $(TOP)/configure/RULES.ioc
>     The base is built for linux-x86.
If EPICS_HOST_ARCH is linux-x86 that Makefile should result in the envPaths
file being created if it doesn't already exist.  There are a number of ways
where misconfiguration of your application could cause problems but I can't
think of any that would cause the build to complete like you show above.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
Re: no envPaths in application of base 3.14.11 Mi Qingru
Prev: EPICS Config for 2 Ethernet Adapters graham.cox
Next: Re: EPICS Config for 2 Ethernet Adapters Paul Sichta
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: no envPaths in application of base 3.14.11 Mi Qingru
Next: Re: no envPaths in application of base 3.14.11 Mi Qingru
