1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Fwd: Re: GigE cameras stops
To: "Bruce Hill" <[email protected]>, <[email protected]>
Date: Thu, 17 Feb 2011 18:18:41 -0600
Is this Linux or Windows?  It is definitely fixed in later releases.
The problem is that the Prosilica driver (the one that they wrote, not mine) uses the new Posix timer functions, which rely on SIGALARM.  SIGALARM can cause system calls to be interrupted, including write() and read(), nanosleep(), etc.  EPICS base required some changes to work correctly when the Posix timer functions were being used.
Sent: Thu 2/17/2011 5:51 PM
To: [email protected]
Subject: Re: Fwd: Re: GigE cameras stops
Pavel found a related thread between Mark and Jeff on EPIC-Talk archives:
http://www.aps.anl.gov/epics/tech-talk/2009/msg00504.php
It looks like an upgrade to 3.14.11 may fix this.
- Bruce
On 2/17/2011 3:31 PM, Bruce Hill wrote:
	We're having a problem with 'CAS: UDP recv errors" that's causing
	our GigE camera IOC's to stop updating images overnight.
	We're running EPICS 3.14.9, asyn R4.10.1, and areaDetector R1-2.
	When the images stop, we get these errors on our console:
	17_14:39:08:CAS: UDP recv error (errno=Interrupted system call)
	17_14:39:09:CAS: UDP recv error (errno=Interrupted system call)
	Googling "Interrupted system call" seems to indicated that repeating the
	system call, in this case, recv_from, may be needed.   It appears that the CA
	code is already doing that.
	I'm hoping that Jeff or Mark, or anyone, may have already seen this problem.
	We've been working on upgrading to 3.14.11 and newer modules, so if this
	problem has already been fixed we may just need to refocus our efforts on
	the upgrade.
	- Bruce
	-------- Original Message --------
Subject: 	Re: GigE cameras stops
Date: 	Thu, 17 Feb 2011 14:45:52 -0800
From: 	Pavel Stoffel <[email protected]> <mailto:[email protected]>
To: 	Hill, Bruce <[email protected]> <mailto:[email protected]>
	Hi Bruce,
	Turned on tracing for cameras:
	It looks like the camera stops working when we get these 'CAS: UDP recv
	errors (errno=Interrupted system call)'.
	Everything before it, repeats for every frame.  In this case, I
	collected 54335 frames before it stopped.
	Here is the tail end of the trace file:
	17_14:38:22:2011/02/17 14:38:22.888 XPP:USR:GIGE1:cam1:ImageCounter_RBV
	devAsynInt32::interruptCallbackInput new value=45326
	17_14:38:23:2011/02/17 14:38:23.088 prosilica:frameCallback:
	frameId=45329, timeStamp=763787.037673
	17_14:38:23:2011/02/17 14:38:23.088 XPP:USR:GIGE1:cam1:ImageCounter_RBV
	devAsynInt32::interruptCallbackInput new value=45327
	17_14:38:23:2011/02/17 14:38:23.288 prosilica:frameCallback:
	frameId=45330, timeStamp=763787.237673
	17_14:38:23:2011/02/17 14:38:23.288 XPP:USR:GIGE1:cam1:ImageCounter_RBV
	devAsynInt32::interruptCallbackInput new value=45328
	17_14:38:23:2011/02/17 14:38:23.488 prosilica:frameCallback:
	frameId=45331, timeStamp=763787.437673
	17_14:38:23:2011/02/17 14:38:23.488 XPP:USR:GIGE1:cam1:ImageCounter_RBV
	devAsynInt32::interruptCallbackInput new value=45329
	17_14:38:23:2011/02/17 14:38:23.688 prosilica:frameCallback:
	frameId=45332, timeStamp=763787.637673
	17_14:38:23:2011/02/17 14:38:23.688 XPP:USR:GIGE1:cam1:ImageCounter_RBV
	devAsynInt32::interruptCallbackInput new value=45330
	17_14:38:23:2011/02/17 14:38:23.888 prosilica:frameCallback:
	frameId=45333, timeStamp=763787.837673
	17_14:38:23:2011/02/17 14:38:23.888 XPP:USR:GIGE1:cam1:ImageCounter_RBV
	devAsynInt32::interruptCallbackInput new value=45331
	17_14:38:24:2011/02/17 14:38:24.088 prosilica:frameCallback:
	frameId=45334, timeStamp=763788.037673
	17_14:38:24:2011/02/17 14:38:24.088 XPP:USR:GIGE1:cam1:ImageCounter_RBV
	devAsynInt32::interruptCallbackInput new value=45332
	17_14:38:24:2011/02/17 14:38:24.288 prosilica:frameCallback:
	frameId=45335, timeStamp=763788.237673
	17_14:38:24:2011/02/17 14:38:24.288 XPP:USR:GIGE1:cam1:ImageCounter_RBV
	devAsynInt32::interruptCallbackInput new value=45333
	17_14:38:24:2011/02/17 14:38:24.456 PS1 addr 0 queueRequest priority 0
	not lockHolder
	17_14:38:24:2011/02/17 14:38:24.456 PS1 callback
	17_14:39:10:CAS: UDP recv error (errno=Interrupted system call)
	17_14:39:17:CAS: UDP recv error (errno=Interrupted system call)
	17_14:39:18:CAS: UDP recv error (errno=Interrupted system call)
	17_14:39:19:CAS: UDP recv error (errno=Interrupted system call)
	17_14:39:32:CAS: UDP recv error (errno=Interrupted system call)
	17_14:39:33:CAS: UDP recv error (errno=Interrupted system call)
	17_14:39:55:CAS: UDP recv error (errno=Interrupted system call)
	Pavel Stoffel wrote:
	> Hi Bruce,
	> The cameras stopped after about 30-40K frames.  IOC 1 had 104 frame
	> errors, IOC 2 1:
	> $ ls-cam1
	> XPP:USR:GIGE1:cam1:ImageRate_RBV 0
	> XPP:USR:GIGE1:cam1:ImageCounter_RBV 42931
	> XPP:USR:GIGE1:cam1:PSBadFrameCounter_RBV 104
	> $ ls-cam2
	> XPP:USR:GIGE2:cam1:ImageRate_RBV 0
	> XPP:USR:GIGE2:cam1:ImageCounter_RBV 29353
	> XPP:USR:GIGE2:cam1:PSBadFrameCounter_RBV 1
	> Don't see any errors in the log file :-(
	> Thanks,
	> Pavel
Fwd: Re: GigE cameras stops Bruce Hill
Re: Fwd: Re: GigE cameras stops Bruce Hill
Prev: RE: Re: GigE cameras stops Jeff Hill
Next: Re: GigE cameras stops Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Fwd: Re: GigE cameras stops Bruce Hill
Next: RE: Re: GigE cameras stops Jeff Hill
