1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: TFTP I/O Error
To: <[email protected]>
Date: Fri, 18 Feb 2011 16:57:40 -0800
Hello all,
I'm trying to get an EPICS test app going on RTEMS on an MVME5500 board, and I'm encountering a problem when trying to get files from a TFTP server.
"Can't open /TFTP/10.80.60.112/epics/mvme5500/st.cmd: I/O error"
My TFTP server logs don't show any attempt at this connection.
I'm using RTEMS 4.10 and EPICS 3.14.12. I am building the apps with the -DOMIT_NFS_SUPPORT flag set in a MINGW environment on a Windows 7 machine with RTEMS-mvme5500 set as the target arch.
I am also able to download that file (and others) from the tftp server while still in the MOTLOAD prompt on the mvme board.
I have the following GEVs set on the mvme board:
mot-/dev/enet1-cipa=10.80.60.142
mot-/dev/enet1-sipa=10.80.60.112
mot-/dev/enet1-snma=255.255.0.0
mot-/dev/enet1-gipa=10.80.60.20
rtems-client-name=mvme5500
epics-script=epics/mvme5500/st.cmd
rtems-dns-server=10.80.60.12
rtems-dns-domainname=pro-dex.com
epics-ntpserver=71.245.107.83
The networking when the application loads seems to be working fine, as I'm able to get time from the NTP server.
I'm not running a BOOTP server, and so I hardcoded these network parameters into bsp_driver_config and rtems_bsdnet_config  in rtems_netconfig.c
Any assistance in this problem would be greatly appreciated. Thank you very much.
Jim Eastman
This e-mail and any attachment(s) are from Pro-Dex, Inc. and may contain information that is confidential or privileged. If you are not the intended recipient, do not read, copy or distribute the e-mail or any attachments. Instead, please notify the sender at the phone number indicated above and delete the e-mail and any attachments. Thank you.
Re: TFTP I/O Error Eric Norum
Prev: Re: Make target_arch only ... doesn't seem to work on 3.14.11 emmanuel_mayssat
Next: Re: TFTP I/O Error Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
