1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epics on FreeBSD: broadcast problem
To: Maren Purves <[email protected]>
Cc: [email protected]
Date: Thu, 24 Feb 2011 14:33:08 +0100
On Thu, 24 Feb 2011 00:34:41 -1000 (HST) Maren Purves
<[email protected]> wrote about Re: epics on FreeBSD: broadcast
problem:
MP> Bit of grasping at straws here: are you sure it starts
MP> a CARepeater?
It is not in the path right now, but I started it by hand earlier.
Otherwise caget complains with a warning on the commandline, but it can
nevertheless resolve the PV name (if the broadcast is set correctly).
I am still working on the hints Jeff sent. I try to install casr, but it
has several dependencies (sdds being one of them) that have obviously not
yet been ported to FreeBSD. I hope to be able to finish that soon (and
will then probably be back with a list of things to change and
hopefully some new info about the broadcasting problem :-).
cu
  Gerrit
Re: epics on FreeBSD: broadcast problem J. Lewis Muir
Re: epics on FreeBSD: broadcast problem Ralph Lange
epics on FreeBSD: broadcast problem Gerrit Kühn
Re: epics on FreeBSD: broadcast problem Gerrit Kühn
Prev: Re: epics on FreeBSD: broadcast problem Ralph Lange
Next: Re: epics on FreeBSD: broadcast problem J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
