1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Gateway/CAS "bad resource" with CAJ?
To: "'Kasemir, Kay'" <[email protected]>, "'TechTalk'" <[email protected]>
Date: Mon, 7 Mar 2011 09:39:40 -0700
Hi Kay,
> Bad resource identifier - unexpected problem with client's input - forcing
> disconnect
I don?t claim to fully understand at this point what's occurring; I created
bug entry 730720 at launchpad so we can work the issue.
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Kasemir, Kay
> Sent: Friday, March 04, 2011 11:37 AM
> To: TechTalk
> Subject: Gateway/CAS "bad resource" with CAJ?
> Hello:
> For what it's worth, we're seeing these messages on a CA Gateway at the
> SNS:
> CAS Request: ... on ....: cmd=2 cid=1 typ=20 cnt=1 psz=0 avail=130
> CAS:
> Mar 04 08:20:39 !!! Errlog message received (message is above)
> bad resource id in "../../../../src/cas/generic/casStrmClient.cc" at line
> 1988
> filename="../../../../src/cas/generic/st/casStreamOS.cc" line number=479
> disconnect
> The messages appear to be caused by pure Java (CAJ) clients running on
> Windows, Linux and Mac OS X.
> The gateway is version 2.0.4.0, based on EPICS R3.14.11.
> CAJ is 1.1.7 with JCA 2.3.3 to 2.3.5 depending on the specific client,
> can't
> say for sure which one is which.
> We are not sure it's a severe problem. The gateway continues to run.
> Since we don't use CAJ on the accelerator network, only on the office
> network where all access is through a read-only gateway, we can't spend
> much
> time on debugging this issue, but sites that depend on CAJ for a
> production
> setup might want to check if they get similar messages.
> Thanks,
> Kay
Re: Gateway/CAS "bad resource" with CAJ? Steven M. Hartman
Gateway/CAS "bad resource" with CAJ? Kasemir, Kay
Prev: Re: Setting inter-character delay in Asyn Eric Norum
Next: Re: Gateway/CAS "bad resource" with CAJ? Steven M. Hartman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Gateway/CAS "bad resource" with CAJ? Kasemir, Kay
