1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PyEpics segmentation faults
To: [email protected], "Vigder, Mark" <[email protected]>
Date: Tue, 8 Mar 2011 14:16:05 -0600
Hi Mark,
Please try applying the patch from the 3.14.12 Known Problems page dated
2011-02-16 to your EPICS Base installation to see if it helps.  This patch has
been reported to fix a couple of CA client issues at different sites now, and
if it helps you too I'll make it more prominent on that page.
  http://www.aps.anl.gov/epics/base/R3-14/12-docs/KnownProblems.html
- Andrew
On Tuesday 08 March 2011 13:45:32 Vigder, Mark wrote:
> I'm running PyEpics 3.0.11, on Ubuntu 10.04.2, Epics 3-14-12, Python 2.6.5,
> linux-x86_64. A while ago (perhaps with earlier versions of something?)
> everything seemed to be working fine. I hadn't used it for a while, but now
> when I fire it up I end up with weird behaviour, e.g.:
> -I type: Motor('XXX:m1'). Returns error, saying 'XXX:m1' is not a motor.
> -I type: Motor('XXX:m1') a second time. This one works.
> -Sometime later, I'll get a 'Segmentation fault'.
> Anybody seen this kind of behaviour? Any ideas what's going on or where I
> should start looking for solutions?
> P.S., I just tried with Python3.1. Same thing.
> Thanks
> Mark
> Mark Vigder
> Canadian Neutron Beam Centre
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
RE: PyEpics segmentation faults Vigder, Mark
Prev: PyEpics segmentation faults Vigder, Mark
Next: RE: PyEpics segmentation faults Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: PyEpics segmentation faults Vigder, Mark
