Hi Mathias,
On Monday 21 March 2011 12:59:41 Steiner, Mathias wrote:
> "calib1" is an ai record of type "Raw Soft Channel."
> It should convert its raw value via the .LINR = typeKdegC breakpoint table.
> Instead, VAL is equal to RVAL and STAT is "Soft."
Did you include the bptTypeKdegC.dbd when you built your IOC's dbd file?
Those symptoms lead me to suspect that the breakpoint table data isn't
actually loaded at all — the standard table definitions are provided with Base
and their names are listed in the menuConvert.dbd file, but you have to
explicitly include the relevant .dbd file when building an IOC that uses it.
That might not be documented anywhere though (sorry!).
HTH,
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
- RE: Breakpoint Table Error Steiner, Mathias
- Breakpoint Table Error Steiner, Mathias
<2011>
2025
2026
<2011>
2025
2026
