1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA and threads
To: [email protected]
Date: Mon, 28 Mar 2011 10:48:43 -0500
On Monday 28 March 2011 09:57:27 Dirk Zimoch wrote:
> If I create a CA client context with
>    ca_context_create (ca_disable_preemptive_callback);
> or, what is the same, with
>    ca_task_initialize();
> in which thread context will then the callback handlers be called? Is it
> in the context of the thread that calls ca_pend_io() or still in the
> context of a separate thread? How was it implemented in 3.13?
In 3.14 the CA client callbacks are *always* made in the context of an
internal CA thread, and never of the thread that called ca_pend_io() /
ca_pend_event().  If you use the above calls to initialize the library the
callbacks are only ever called while the other thread is still executing the
ca_pend_*() library routine, so you do not have to include mutexes in your
code.
It occurs to me that there *could* be some circumstances where that's not
strictly true, if the ca_pend_* thread responds to a signal, but that would be
fairly unusual and would probably break the rules for signal handlers anyway.
In 3.13 the callbacks were made from the thread that called ca_pend_*(), CA
was not multi-threaded internally and did all its I/O using the select() OS
call.  The CAS still uses this approach.
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
Re: CA and threads Dirk Zimoch
Prev: 64-bit Channel Archiver Robert Petkus
Next: Re: how to build c++ Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CA and threads Dirk Zimoch
Next: Re: CA and threads Dirk Zimoch
