1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Ether/IP array limits
To: Stephen Lewis <[email protected]>, "[email protected]" <[email protected]>
Cc: "Maida, Ricardo E." <[email protected]>
Date: Tue, 5 Apr 2011 21:11:11 -0700
If you are talking about PLC data type REAL, the ether_ip readme advises a maximum array size of 40. For BOOL arrays the max recommended size is 350.
Excerpt from the readme:
"Arrays should be one-directional: Use separate "EPICS to PLC" and "PLC
to EPICS" arrays. Because of PLC buffer limitations, the array size is
unfortunately limited to about BOOL[350] and REAL[40]. While you can
define bigger arrays, those cannot be transferred over the network
with EtherIP. Consequently you might end up with several transfer arrays."
(See http://epics.hg.sourceforge.net/hgweb/epics/ether_ip/file/tip/ether_ipApp/doc/readme.txt)
-Stephen
From: [email protected] [[email protected]] On Behalf Of Stephen Lewis [[email protected]]
Sent: Tuesday, April 05, 2011 3:53 PM
To: [email protected]
Cc: Stephen Schuh; Maida, Ricardo E.
Subject: Ether/IP array limits
We are using ether-ip-R2-5 with Allen-Bradley ControlLogix PLCs and version 15 of the AB (Rockwell) ladder logic.  Our previous engineer limited the arrays that are used to block transmit and receive variables to and from EPICS to 32 elements.  Is there a limit or can they safely be expanded to 64 elements?  The soft IOCs are hosted on RedHat Linux 4, 32-bit, built against base 3.14.9.
--Steve
Stephen Lewis
[email protected]<mailto:[email protected]>
Linac Coherent Light Source
SLAC National Accelerator Lab
2575 Sand Hill Rd | M/S-10
Menlo Park, CA 94025
Re: Ether/IP array limits Kasemir, Kay
Ether/IP array limits Stephen Lewis
Prev: Ether/IP array limits Stephen Lewis
Next: Re: Ether/IP array limits Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
