1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Python EPICS interface (pyepics 3.1.1) double waveform record ( NLEM = 65535 ) record handling exception
To: [email protected]
Date: Tue, 12 Apr 2011 17:29:33 +0200
Dear sir,
My Enviorment is
pyepics-3.1.1,
python 3.2
Linux kernal  2.6.18-194 ; 64 bit
Context: Testing pyepics library
Problem:
I am using supplied database (test/pydebug.db) and I am not able to use the double wave form record of 64k elements. while double wave form record of 2k elements works fine.
Any suggestion are welcome.
Best regards
---- EPICS shell------------------
epics> dbpr Py:double64k 2
ACKS: NO_ALARM      ACKT: YES           APST: Always        ASG:
BKPT: 00            BUSY: 0             DESC: long double waveform
DISA: 0             DISP: 0             DISS: NO_ALARM      DISV: 1
DTYP: Soft Channel  EGU:                EVNT: 0             FLNK:CONSTANT 0
FTVL: DOUBLE        HOPR: 0             INP:CONSTANT        LCNT: 0
LOPR: 0             MPST: Always        NAME: Py:double64k  NELM: 65536
NORD: 0             NSEV: NO_ALARM      NSTA: NO_ALARM      PACT: 0
PHAS: 0             PINI: NO            PREC: 0             PRIO: LOW
PUTF: 0             RARM: 0             RPRO: 0             SCAN: Passive
SDIS:CONSTANT       SEVR: INVALID       SIML:CONSTANT       SIMM: NO
SIMS: NO_ALARM      SIOL:CONSTANT       STAT: UDF           TIME: <undefined>
TPRO: 0             TSE: 0              TSEL:CONSTANT       UDF: 1
VAL: (nil)
------------- Python shell -----------------------------
>>> pv1=PV('Py:double64k')
Traceback (most recent call last):
  File "_ctypes/callbacks.c", line 259, in 'calling callback function'
  File "/home/ITER/sugandr/Desktop/epics-python/Python-3.2/lib/python3.2/site-packages/epics/ca.py", line 391, in _onGetEvent
>>>     value = dbr.cast_args(args).contents
ValueError: NULL pointer access
Re: Python EPICS interface (pyepics 3.1.1) double waveform record ( NLEM = 65535 ) record handling exception Matt Newville
Prev: How to execute CSS/BOY directly in OPIruntime mode ? patard
Next: Re: Python EPICS interface (pyepics 3.1.1) double waveform record ( NLEM = 65535 ) record handling exception Matt Newville
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: How to execute CSS/BOY directly in OPIruntime mode ? Chen, Xihui
