1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Increase event number limit
To: [email protected]
Cc: [email protected]
Date: Fri, 15 Apr 2011 09:51:02 +0200
Hi Euan,
That should be no problem. Of course then your database becomes incompatible with "normal" versions of EPICS base so that you need to be careful when upgrading your EPICS version or exporting your database to other EPICS users. But since the effect of the modification is limited to the IOCs, it is compatible with any EPICS version on other IOCs and any client software.
The maximum number is 32768 because the EVNT field is a DBF_SHORT.
You may also be interested in my code to use strings instead of numbers for soft events from the codeathlon 2010. Unfortunately it didn't make it into 3.14.12.
https://code.launchpad.net/~dirk.zimoch/epics-base/named-soft-events/+merge/39472
Best regards,
Dirk
[email protected] wrote:
In the EPICS applications developers guide the following is presented:
 17.4.2 Event Scanning
Event scanning is built around the following definitions:
#define MAX_EVENTS 256
typedef struct event_scan_list {
    CALLBACK        callback;
    scan_list       scan_list;
} event_scan_list;
static event_scan_list
*pevent_list[NUM_CALLBACK_PRIORITIES][MAX_EVENTS];
Is it possible to increase the MAX_NUMBER definition to enable more event numbers to be used in a linux soft IOC?
cheers,
Euan.
Euan Troup CSIRO Astronomy & Space Science    +61 2 9372 4660
[email protected]<mailto:[email protected]>
Increase event number limit Euan.Troup
Prev: Does EPICS Base support multi-thread on vxWorks 6.3? lorna . zhang
Next: New sequencer bugfix release candidate Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Increase event number limit Euan.Troup
Next: Does EPICS Base support multi-thread on vxWorks 6.3? lorna . zhang
