Hi Andrew,
Thank you for your input.
With TPRO set to 1, I get:
epics> CAS-client: Process TEST:AO:TEST
CAS-client: Process TEST:AI:TEST
when the button is clicked, and
when the IOC is restarted.
Only one button is available, which is EPICS "aware".
Thanks again,
Zen
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Friday, April 15, 2011 1:27 PM
> To: [email protected]
> Cc: Szalata, Zenon M.; Andrew Rhyder
> Subject: Re: epicsQt
> Hi Zen,
> On Friday 15 April 2011 15:03:43 Szalata, Zenon M. wrote:
> > I start camonitor TEST:AI:TEST, then the IOC, then the GUI. All seem well.
> > camonitor reports value 0.
> > I restart the IOC, camonitor reports PV disconnected, then it connects and
> > shows value 0. So far so good.
> > Now I click the push button, camonitor reports value 1.75 as it should.
> > shows value 1.75!
> > From now on, after restarting the IOC, the ai record ends up with
> > value=1.75, even though I am not clicking the push button. Appears that
> > the ao record is getting processed when the push button connects to the
> > PV when the IOC starts up. This continues as long as the QT GUI is up.
> > When I stop the QT GUI and restart the IOC, then restarting the IOC does
> > not get the value transferred from the ao to the ai record.
> This sounds like it has to be an epicsQt issue. Try setting the TPRO field of
> your TEST:AO:TEST record in the .db file; that results in a message being
> printed on the IOC console whenever the record processes, and it tells you
> which thread is causing the processing on restarting the IOC. I'm going to
> bet that you'll see it coming from the same CA thread as when you first push
> the button.
> > Am I doing something wrong configuring the epicsQt push button or is there
> > a bug in the epicsQt CA part of the software? I am assuming that this
> > behavior is not built in intentionally.
> Does epicsQt have more than one kind of push button? I would like for
> something like a momentary action button if there is an alternative you can
> use. It sounds like the one you're using is designed to restore the last
> value it sent when the IOC reconnects, which isn't what you actually want it
> to do.
> HTH,
> - Andrew
> An error is only a mistake if you don't learn from it.
> When you learn something from it, it becomes a lesson.
- RE: epicsQt Andrew Rhyder
- epicsQt Szalata, Zenon M.
- Re: epicsQt Andrew Johnson
RE: Any upcoming EPICS training Paul Martin
<2011>
2025
2026
<2011>
2025
2026
