1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Question regarding CaChannel -v1.6 compilation using python-3.2 on linux 86-64 bit
To: [email protected]
Cc: Di Maio Franck <[email protected]>
Date: Mon, 18 Apr 2011 11:50:35 +0200
Dear Sir,
I am trying to compile CaChannel v1.6 using python-3.2 on linux x86-64. The compilation  gives following error. Does CaChannel supports python3 ?
Seeking suggestions and comments
Best regards,
Ritesh Sugandhi
command line output::
$ python3 setup.py build
running build
running build_py
running build_ext
building '_ca' extension
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPYCA_VERSION="\"1.7\"" -DLinux -UW -UI -UT -UH -U_ -UT -UK -I/opt/codac-2.0/epics/base/include -I/opt/codac-2.0/epics/base/include/os/Linux -I/opt/codac-2.0/epics/base/include/os -I/home/ITER/sugandr/Desktop/epics-python/Python-3.2/include/python3.2m -c _ca314.cpp -o build/temp.linux-x86_64-3.2/_ca314.o
cc1plus: warning: command line option "-Wstrict-prototypes" is valid for Ada/C/ObjC but not for C++
_ca314.cpp: In function \u2018void init_ca()\u2019:
_ca314.cpp:396: error: \u2018Py_InitModule\u2019 was not declared in this scope
_ca314.cpp:404: error: \u2018PyString_FromString\u2019 was not declared in this scope
_conv_helper.cpp: In function \u2018PyObject* _convert_ca_to_Python(chtype, long unsigned int, void*, int)\u2019:
_conv_helper.cpp:242: error: \u2018PyString_FromString\u2019 was not declared in this scope
_conv_helper.cpp:366: error: \u2018PyString_FromString\u2019 was not declared in this scope
_ca314.cpp: In function \u2018PyObject* Py_ca_monitor(PyObject*, PyObject*)\u2019:
_ca314.cpp:1479: error: \u2018PyCObject_FromVoidPtr\u2019 was not declared in this scope
_ca314.cpp: In function \u2018PyObject* Py_ca_clear_monitor(PyObject*, PyObject*)\u2019:
_ca314.cpp:1496: error: \u2018PyCObject_AsVoidPtr\u2019 was not declared in this scope
_ca314.cpp: In function \u2018PyObject* Py_ca_name(PyObject*, PyObject*)\u2019:
_ca314.cpp:1707: error: \u2018PyString_FromString\u2019 was not declared in this scope
_ca314.cpp: In function \u2018PyObject* Py_dbf_text(PyObject*, PyObject*)\u2019:
_ca314.cpp:1721: error: \u2018PyString_FromString\u2019 was not declared in this scope
_ca314.cpp: In function \u2018PyObject* Py_dbr_text(PyObject*, PyObject*)\u2019:
_ca314.cpp:1735: error: \u2018PyString_FromString\u2019 was not declared in this scope
_ca314.cpp: At global scope:
_ca314.cpp:331: warning: \u2018void ca_context_destroy_wrapper()\u2019 defined but not used
error: command 'gcc' failed with exit status 1
RE: Question regarding CaChannel -v1.6 compilation using python-3.2 onlinux 86-64 bit Wang Xiaoqiang
Prev: Re: Does EPICS Base support multi-thread on vxWorks 6.3? lorna . zhang
Next: RE: Question regarding CaChannel -v1.6 compilation using python-3.2 onlinux 86-64 bit Wang Xiaoqiang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS Device Support for the Sis3302 Ernest L. Williams Jr.
