1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to know type of record at client end [Py-epics v3.1.1 interface ]
To: Ritesh Sugandhi <[email protected]>
Cc: [email protected]
Date: Mon, 18 Apr 2011 17:10:27 +0200
epics.PV('Py:ai1.RTYP')
Ritesh Sugandhi wrote:
Dear Sir,
Is there is any way, one can know the type of record, if I know the PV name.
e.g. I have a analog input record Py:ai1
 >>> pv=epics.PV('Py:ai1')
 >>> pv.type
'double'
 >>> pv.count
1
 >>> pv.get_ctrlvars()
{'status': 17, 'lower_disp_limit': 0.0, 'upper_disp_limit': 0.0, 'severity': 3, 'upper_ctrl_limit': 0.0, 'lower_alarm_limit': nan, 'precision': 0, 'upper_alarm_limit': nan, 'lower_warning_limit': nan, 'upper_warning_limit': nan, 'units': '', 'lower_ctrl_limit': 0.0}
 >>> pv.info <http://pv.info>
"== Py:ai1 (native_double) ==\n value = 1\n char_value = '1'\n count = 1\n type = double\n units = \n precision = 0\n host = trunk.codac.iter.org:42293 <http://trunk.codac.iter.org:42293>\n access = read/write\n status = 17\n severity = 3\n timestamp = 1303134187.996 (2011-04-18 15:43:07.996138)\n upper_ctrl_limit = 0.0\n lower_ctrl_limit = 0.0\n upper_disp_limit = 0.0\n lower_disp_limit = 0.0\n upper_alarm_limit = nan\n lower_alarm_limit = nan\n upper_warning_limit = nan\n lower_warning_limit = nan\n PV is internally monitored, with 0 user-defined callbacks:\n============================="
How does I get it is of record type analog input e.g. (ai). One way is to get it from output string . Is there is a simple way ?
Best regards,
Ritesh Sugandhi
How to know type of record at client end [Py-epics v3.1.1 interface ] Ritesh Sugandhi
Prev: Re: How to know type of record at client end [Py-epics v3.1.1 interface ] Ron Sluiter
Next: RE: epicsQt Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: How to know type of record at client end [Py-epics v3.1.1 interface ] Ritesh Sugandhi
