1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: question about fix for AssyGeneric_scanrec_v2.db patch in tpmac module (results in 0.25 s minimum move time)
To: Jay Steele <[email protected]>
Date: Tue, 19 Apr 2011 13:42:47 -0500
On 4/19/11 1:16 PM, Jay Steele wrote:
>        Does anybody have any ideas or implementations to fix
>        TPMAC so that there isn't this minimum move time of
>        0.25 second? I have not dug into the internal logic yet
>        but thought I would check with the EPICS community
>        first.
Hi, Jay.
The last paragraph of the comment (i.e. "A cleaner fix ...")
includes some suggestions on possible ways to do that.
However, I think at some point you will come up against the rate
at which the PMAC is being polled by the driver.  I think this
is 10 Hz right now.  If you need to get that move time below 0.1
seconds, I think the driver poll rate would need to be increased.
Lewis
Re: question about fix for AssyGeneric_scanrec_v2.db patch in tpmac module (results in 0.25 s minimum move time) Daron Chabot
question about fix for AssyGeneric_scanrec_v2.db patch in tpmac module (results in 0.25 s minimum move time) Jay Steele
Prev: question about fix for AssyGeneric_scanrec_v2.db patch in tpmac module (results in 0.25 s minimum move time) Jay Steele
Next: Re: question about fix for AssyGeneric_scanrec_v2.db patch in tpmac module (results in 0.25 s minimum move time) Daron Chabot
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
