1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: seq-2-0-13-rc2
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Thu, 21 Apr 2011 13:44:56 -0500
On 4/20/11 11:21 AM, Benjamin Franksen wrote:
> This is a second release candidate for seq-2.0.13. I followed Andrew's
> suggestions and moved the error detection for assign to 64 bit long from snc
> to the C compiler (via #if ... #error...). This version should now complain
> if and only if the program contains an assign clause for a long or unsigned
> long *and* the program is compiled for an architecture where a long is
> larger than 4 bytes.
Hi, Ben.
Now the build fails trying to build tooLong.st.  The build log
is at
<https://www.imca.aps.anl.gov/~jlmuir/tmp/seq-2.0.13-rc2-build.txt>.
If I remove "PROD += tooLong" from test/validate/Makefile, the
build completes successfully.  The build log for this is at
<https://www.imca.aps.anl.gov/~jlmuir/tmp/seq-2.0.13-rc2-build-r1.txt>.
The host was running RHEL 5.6 and the GCC version was "4.1.2
20080704 (Red Hat 4.1.2-50)".
Lewis
Re: seq-2-0-13-rc2 Benjamin Franksen
New sequencer bugfix release candidate Benjamin Franksen
Prev: Re: PyEpics and Python threads Matt Newville
Next: Re: shell command arguments limitation? Daron Chabot
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: shell command arguments limitation? Daron Chabot
Next: Re: seq-2-0-13-rc2 Benjamin Franksen
