Subject: |
Handle leak in Channel Access Server V4.13 (current EPICS base) - WinXP |
Carsten Winkler <[email protected]> |
To: |
Date: |
Wed, 27 Apr 2011 13:28:47 +0200 |
It seems to be a handle leak in Channel Access Server V4.13 (current EPICS base)
Create any PVs at softIoc, request it via caget and you see the handle count at softIoc will be
increased by two and won't be freed anymore (without using any EPICS gateway).
If you frequently repeat this procedure you will end up to in a "WINSOCK Error 10055".
This problem occurs at Windows XP with patched EPICS bas 3.14.12.
How can I fix this bug without using EPICS gateways?
Best Regards,
Carsten Winkler
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
- RE: Handle leak in Channel Access Server V4.13 (current EPICS base) - WinXP Jeff Hill
Re: Re: VMIC VMIVME 4105 register cannot be modified? 马晓媛
Large number of sequencers running per soft IOC under Linux: Kernel becomes unresponsive Ernest L. Williams Jr.
<2011>
2025
2026
EPICS R3.14.12.1 Released Andrew Johnson
<2011>
2025
2026
