1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Handling failures in st.cmd
To: <[email protected]>
Date: Fri, 13 May 2011 02:31:28 +0200
Am Freitag, 13. Mai 2011, um 02:07:20 schrieb Ernest L. Williams Jr.:
> Till Straumann wrote:
> > On 05/12/2011 05:22 PM, Zelazny, Michael Stanley wrote:
> >> If, for example, dbLoadRecords, initializing some hardware module,
> >> cd("some/dir"), etc. fails while an IOC is booting, is there any way to
> >> trap this in my st.cmd and take an action, such as abort the IOC boot?
> > Under RTEMS (cexpsh shell -- every line is a C expression)
> > you can easily do that (provided that the routine you want to trap
> > returns a status)
> > dbLoadRecords(...) && bsp_reset()
> > will reset the board if dbLoadRecords() returns
> > a non-zero value.
> > However, rebooting is maybe not the best way to
> > handle this since you will most likely end up in
> > an endless loop (since the error condition doesn't
> > go away with a reboot).
> What we really want is for the whole process to just stop.
> For example, in RTEMS if there is an undefined symbol the system errors
> out and stops.
> Or is that vxWorks, I am thinking of?
If I remember correctly,  I have once done this for VxWorks by calling
exit(EXIT_FAILURE). This will abort the shell task and the boot process stops.
It will, however, not stop other tasks that have aleady been started, so is
useful only until shortly before iocInit completes.
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: Handling failures in st.cmd Till Straumann
Handling failures in st.cmd Zelazny, Michael Stanley
Re: Handling failures in st.cmd Ernest L. Williams Jr.
Prev: Re: Handling failures in st.cmd Ernest L. Williams Jr.
Next: Re: Handling failures in st.cmd Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
