1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: problem with gateway and softIoc running on same server
To: <[email protected]>
Date: Wed, 18 May 2011 17:49:03 -1000
I want a gateway to publish PVs from 192.168.134.51:8064 which is on a private network connected to 192.171.95.112 (where a softIoc is already running) because I can’t access this private
I have the situation where I have a solaris-8 server (192.171.95.112) with two network cards.  One goes to our observatory network and the other goes to a private network running a windows based softIoc (192.168.134.51).  Now I need access to the PVs of the widows softIoc from other IPs on the observatory network.
I can successfully get the gateway to publish the windows softIoc PVs without any problems.  However, I have a solaris softIoc running on the same server as the gateway and this is where I’m having problems. I’ve tried using different EPICS_CA_SERVER_PORTS for both IOCs but no matter what I try I can’t get the gateway to see the solaris IOC on the same IP.  If I manually set my EPICS_CA_SERVER_PORT at the command line then issue a caget, it successfully returns the PV value but it reports that there’s multiple instances of the PV.
My question is: can a gateway co-exist with a softIoc in the same ip address?
If so, what do I need to do to make it happen?  Using different EPICS_CA_SERVER_PORTs doesn’t seem to be it.  Is this related to the fact that I can’t run multiple softIocs on the same server unless I change port numbers?  In which case I’d want a gateway to interface to them as well.
Here’s my startup command run on the solaris server (128.171.95.112):
/usr/local/epics/r3.14.9/extensions/bin/solaris-sparc-gnu/gateway -debug 1 -pvlist k1lmct.pvlist -access GATEWAY.access -home $HOME -log k1lmct.log -sip "128.171.95.112" -sport 5064 -cip "192.171.95.112:8164 192.168.134.51:8064" -prefix k1:lmct:gateway&
Here’s the start of the debug output log:
PV Gateway Version 2.0.3.0 [Feb 20 2008 16:27:23]
EPICS 3.14.9 PID=13539
EPICS_CA_ADDR_LIST=192.171.95.112:8164 192.168.134.51:8064
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_CA_SERVER_PORT=Not specified
EPICS_CA_MAX_ARRAY_BYTES=Not specified
EPICS_CAS_INTF_ADDR_LIST=128.171.95.112
EPICS_CAS_SERVER_PORT=5064
EPICS_CAS_IGNORE_ADDR_LIST=Not specified
Thank you in advance!
Kevin Tsubota
W.M. Keck Observatory
Re: problem with gateway and softIoc running on same server Dirk Zimoch
Re: problem with gateway and softIoc running on same server Ralph Lange
Prev: Re: Visit of SLAC/ALS control room? emmanuel_mayssat
Next: Re: problem with gateway and softIoc running on same server Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: multi-threaded client example Jeff Hill
