10 seconds is the default timeout for channels that are not found.
Can you please show the command line you are using and its output?
It would also be useful to know which system you are running caget
on, and which version of EPICS you are using.
~Ralph
On 31.05.2011 04:17 lailongwei wrote:
hi,
when I use caget A, though the data has been gotten, it
holds for about ten sends untill the command exit.
This cause problem when I need to caget four PVs, whose
sampling at the same time is very important. How can I solve it.
Thanks!
2011-05-31
lailongwei
- RE: caget command holds for more than 10 seconds Mark Rivers
- caget command holds for more than 10 seconds lailongwei
<2011>
2025
2026
<2011>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
