1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caget command holds for more than 10 seconds
To: lailongwei <[email protected]>
Date: Tue, 31 May 2011 14:13:38 +0200
lailongwei wrote:
hi,
when I use caget A, though the data has been gotten, it holds for about ten sends untill the command exit. This cause problem when I need to caget four PVs, whose sampling at the same time is very important. How can I solve it.
Thanks!
2011-05-31
lailongwei
One could argue that strictly speaking sampling over the network is "wrong". TCP and thus CA does not support any real-time behavior. So the best way to solve it is to sample all four PVs on the same real-time IOC. This probably does not help when the PVs are not physically connected to the same IOC. For the future SwissFEL project, we (meaning Babak) took great effort to implement this kind of synchronous data acquisition across multiple IOCs. Our implementation strongly depends on our timing system to synchronize PVs on multiple IOCs. This is nothing you can quickly do with a 'caget a; cage b; caget c; caget d;'
Dirk
RE: caget command holds for more than 10 seconds Mark Rivers
caget command holds for more than 10 seconds lailongwei
Prev: RE: caget command holds for more than 10 seconds Mark Rivers
Next: RE: caget command holds for more than 10 seconds Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: caget command holds for more than 10 seconds Ralph Lange
