1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Sequencer news: latest snapshot builds and runs under Windows
To: <[email protected]>
Date: Tue, 31 May 2011 22:34:23 +0200
the latest snapshot I uploaded today fixes all the build problems on native
win32 (I used Windows XP running in a VM under Ubuntu and EPICS base
3.14.12.1). I have not yet installed cygwin so this platform may still have
problems.
The tests also build and run w/o errors. However, 'make runtests' sometimes
hangs in the middle of executing the validation tests; restarting it (after a
Ctrl-C) usually helps. I have not found out what exactly causes these hangups,
but I am almost certain that there is something wrong with the perl test
harness, since I never experienced them when running the test scripts manually
(i.e. 'cd test/validate/O.$(T_A); perl xxx.t').
BTW,  I had to make *no* functional changes to the sequencer or compiler code
to make the test suite run through. The only things I had to change were
- many details in the build system
- replace all uses of C99 features by proper conservative C90
- add some Windows specific header includes
- adapt the test script builder
All this makes me confident that a release candidate for 2.1.0 is not too far
off.
BTW, I found a small bug in the EPICS build rules that causes errors when
using 'make -s' on (native) Windows: the definition of the ECHO variable uses
"#" (instead of the echo command) if the MAKEFLAGS contain 's', however on
native Windows "#" does not start a comment! Instead you get "error command #
not found". Using "REM" on Windows fixes this. The snapshot contains a patch
that supplies a workaround by overriding ECHO.
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Prev: Re: How does EPICS increment its clock for timestamp Andrew Johnson
Next: EPICS on Delta Tau Power PMAC Bill Cruise
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
