1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: pyEpics want postponed connecting
To: [email protected]
Date: Thu, 02 Jun 2011 10:42:02 +0200
We are using pyEpics 3.1.1 for our application. The web page states that CA connection can be performed auto-magically at ca.create_channel() call, by calling ca.connect_channel(). This works fine. The connection can also be postponed, by supplying the connect=False argument, the docs also say.
We are unable to achieve the postponed connection. In the example I'm supplying both connections are made instantly, even though the first one has connect=False set.
Is there a way to achieve the delayed connection? We would need this to more precisely control which PVs are actually 'enabled'/'used' in the application ..
Example:
import epics
import time
import sys
def onConnectionChange(pvname=None, conn=None, chid=None):
print 'ca connection status changed: ', time.time(), pvname, conn, chid
    sys.stdout.flush()
# create channel, provide connection callback
pv1 = 'HINKS:ENV:ENV_VOLTAGE1_MONITOR'
chid1 = epics.ca.create_channel(pv1, connect=False, callback=onConnectionChange)
pv2 = 'HINKS:ENV:ENV_VOLTAGE1_MONITOR'
chid2 = epics.ca.create_channel(pv1, connect=True, callback=onConnectionChange)
print 'Now waiting, watching values and connection changes:'
t0 = time.time()
while time.time()-t0 < 30:
    time.sleep(0.001)
print "Exiting .."
Example output:
$ python caconnect.py
ca connection status changed: 1307003655.84 HINKS:ENV:ENV_VOLTAGE1_MONITOR True 162902648 ca connection status changed: 1307003655.84 HINKS:ENV:ENV_VOLTAGE1_MONITOR True 162902648
Thank you!
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review, retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
Re: pyEpics want postponed connecting Hinko Kocevar
Re: pyEpics want postponed connecting Matt Newville
Prev: Re: EPICS Base darwin-x86_64 target architecture? Andrew Johnson
Next: Re: pyEpics want postponed connecting Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS Base darwin-x86_64 target architecture? J. Lewis Muir
