1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caget command holds for more than 10 seconds
To: [email protected]
Date: Thu, 02 Jun 2011 13:44:48 +0200
Dear lailongwei,
On 05/31/2011 04:17 AM, lailongwei wrote:
hi,
when I use caget A, though the data has been gotten, it holds for about
ten sends untill the command exit.
This cause problem when I need to caget four PVs, whose sampling at the
same time is very important. How can I solve it.
Are you using Ubuntu?
Can you try modifying the 'hosts:' line in /etc/nsswitch.conf to contain ONLY:
hosts:          files dns
It helped in our environment..
BR,
Hinko
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review, retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
caget command holds for more than 10 seconds lailongwei
Prev: Re: pyEpics want postponed connecting Hinko Kocevar
Next: Re: pyEpics want postponed connecting Matt Newville
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: caget command holds for more than 10 seconds Mark Rivers
Next: RE: asyn driver on Windows XP Mark Rivers
