1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Compiling Problem windows
To: "Brands Helge" <[email protected]>, <[email protected]>
Date: Mon, 6 Jun 2011 11:15:44 -0500
Hi Helge,
I am curious what version of "make" you are using.  Is it Cygwin make, and if so what version?  I was under the impression that recent versions of Cygwin make did not work for win32-x86 or windows-x64.
On a related topic, I tried using the latest MingGW make (3.82) on win32-x86 and windows-x64 the other day, and found a problem.  It was treating C files as if they were C++ files, which caused errors.  This was when compiling the snapshot version of seq, but I think it is a more general problem.
When I switched to the GnuWin version of make (3.81) the problem went away.
From: [email protected] [mailto:[email protected]] On Behalf Of Brands Helge
Sent: Monday, June 06, 2011 2:54 AM
To: [email protected]
Subject: Compiling Problem windows
I have some troubles with make on windows-x64 since the revision 12242 I got :
/bin/sh: REM: command not found
make[3]: *** [../../../bin/windows-x64/convertRelease.pl] Error 127
make[2]: *** [install.windows-x64] Error 2
make[1]: *** [tools.install] Error 2
make: *** [src.install] Error 2
The cygwin-x86 and the win32-x86 on the same machine runs without any problem
Best
        Helge
RE: Compiling Problem windows Brands Helge
Prev: RE: Dynamic images in BOY Mark Rivers
Next: Check vxWorks architecture Chen Xue
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Compiling Problem windows Andrew Johnson
Next: RE: Compiling Problem windows Brands Helge
